Samsung SP50L7 box size
Discussion in 'General TV Discussions Forum' started by clarky78, Jul 13, 2005.
  1. clarky78
    clarky78
    Nov 8, 2004
    1,879
    Helsinki, Finland
    +41
    Does anyone know the box dimensions, i might be getting one off these and not sure it will fit in my van as its been panelled out.
  2. clarky78
    clarky78
    Nov 8, 2004
    1,879
    Helsinki, Finland
    +41
    surely someone has a box or an idea?
  3. soni
    soni
    Oct 22, 2004
    557
    Kent
    Clarky - Sorry i can't be to specific, as the box has been broken down and put in the loft - but, it was absolutely blinking massive!!
    I hired a Merc Turbo Diesel jobby to get mine home - and that was more than adequate but it was a monster of a van, i would say it was bigger than those post vans!
    From memory (and it is only memory) i would say it must have been about 5ft 8" tall, about 6ft wide, and about 2ft deep - as i say these are only approximate, but i wouldn't say its that far off :smashin:
  4. clarky78
    clarky78
    Nov 8, 2004
    1,879
    Helsinki, Finland
    +41
    Blimey thats huge! Still, think it might fit in :rolleyes: Thanks for your help.
    NOw just to decide if it's this or the 42" plasma on the wall :confused:
  5. Chumpy
    Chumpy
  6. cervaro
    cervaro
    Dec 14, 2002
    48
    How is the box made up? Is it wood given the weight quoted in the other thread?
  7. soni
    soni
    Oct 22, 2004
    557
    Kent
    No its not wooden - its like in two sections. The bottom part is in one piece and then the sides end and top are in anothe part. The sides, ends, and top sought of fit over the bottom part, which i think was sought of held together by some plastic catches. Its also got really thick card tubing in each corner which i suppose add to the weight :smashin:
