Samsung SP50L6H question
Discussion in 'Televisions' started by lukej, Sep 9, 2005.
  1. lukej
    lukej
    Dec 23, 2001
    71
    Does the Samsung SP50L6H use the latest HD4 dlp chip or the older HD3?
    I ask this because i cannot find a spec sheet or any info this tv.
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,214
    103
    Nottingham
    +290
    This had been discussed at depth but the consensus is that the L6 uses the latest HD4 chip.
  3. oreoshake
    oreoshake
    Sep 21, 2005
    4
    It still uses the HD3 chip.
  4. Starfleet
    Starfleet
    Aug 16, 2005
    157
    Birmingham
    what about the sp 46l6hx which chip does it have?
  5. neilmcl
    neilmcl
    Oct 29, 2004
    6,214
    103
    Nottingham
    +290
    I'll think you'll find that the L6 range uses the newer HD4 chip.
  6. oreoshake
    oreoshake
    Sep 21, 2005
    4
    The SP-50L6HR which is available in the Philippines uses the HD3 chip. I think its the same set as SP-50L6HX, which is available in other Asian countries.
  7. neilmcl
    neilmcl
    Oct 29, 2004
    6,214
    103
    Nottingham
    +290
    How do you know it uses the HD3 chip? The dead giveaway for it being HD4 is the native contrast ratio of 2000:1. The HD3 chip can only achieve 1500:1 as in the older SP46L3HX model. If you read the other posts on this you'll see the various documented evidence of the use of HD4.
    Having said that I can't comment on models sold outside of the UK.
  8. oreoshake
    oreoshake
    Sep 21, 2005
    4
    The SP-50L6H series which uses the Panel type 0.55" DMD, uses the HD3 chip as specified on the Philippine samsung website. It has a contrast ratio of 2000:1. and if u look at this forum (http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=493443) and look for the 64 series released in Canada, it states that the HD3 chip dlp tv is capable of a contrast ratio of up to 2000:1.
  9. neilmcl
    neilmcl
    Oct 29, 2004
    6,214
    103
    Nottingham
    +290
