Logan09 said:I need more shelving space for my SP50 and was wondering do samsung make a stand (like the triangular stand that comes with it) that fits onto the right hand side of the TV? If so is there anywhere you can buy them seperate from the TV?
Logan09 said:Thanks guys. ~~ RPH ~~ - by modifying the stand, I presume you mean turning the base triangle piece upside down and adding some feet. This would work, but having seen the prices of the stands I'm looking for another solution.
Basically I need one more bit of shelving space for my Amp (which won't fit on either of the 2 bottom shelves because it's too tall - and currently my HTPC is on the top shelf).
I was wondering if anyone had had to deal with a similar problem or had any good (cheap) solutions that look good.
