Samsung sp50 or the Hitachi ld7200
Discussion in 'General TV Discussions Forum' started by b!lly, Sep 21, 2005.
  1. b!lly
    b!lly
    help,help i cant decide between the 2,what would be the better choice,the dlp sammy or the lcd hitachi ld7200, :lease:
  2. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    On this forum, the Sammy SP50 obviously. :D
    Pro's - Size, looks, PQ, cost
    Con's - Size, looks, rainbows
    The SP50 can now be picked up for less than £1,800. You get a lot of screen for your money.
  3. b!lly
    b!lly
    yes well samsung can get for £1800 looks awsoeme and is massive.
    hitachi looks pretty good too only costs £1200 but is only 32" but seems to be one of the best lcd screens available
    i would be using the screens for movies,general sky digital viewing,dvd,s and ps2(ps3 when released),
    but cant decide which i would be better off with in the long run
  4. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Hardly a like for like comparison as one is a 50" screen and the other is a 32".
    But if you are likely to be playing a lot of games, then you have to consider the screen "lag" factor with fast movement on the LCD set due to the slower refresh rate of the screen.
    I would say it's a no brainer. The Samsung is a superb set with stunning PQ, and what's more is miles more screen for your £££. The only reason I'd even consider the LCD was if I definitely had to have a set that I could hang on the wall.
  5. b!lly
    b!lly
    welll thanks for the input guys,i know there aint much of a comparison to 32" and 50" but i wasnt sure if the bigger the screen i was getting then i would lose some pq,but seems not the case............
    looks like its time to order the sammy sp50.
    thnx
