Samsung sp50 input from PC question.
Discussion in 'Televisions' started by DLPMaybe, May 26, 2005.
  1. DLPMaybe
    DLPMaybe
    Mar 16, 2005
    933
    +52
    I am having a PC built.
    I am going to use it as a HTPC.
    This will be attached to my SP50.
    I do not have a DVI compatable monitor.
    So my question is; when the PC is delivered if the resolution that is active is not supported by the SP50 will I see anything on the TV?
    If not how will I modify the resolution without being able to see the screen?
    Should I ask the company that is building the PC to set the resolution to a certain value? If so what?
    Thanks!
  2. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
  3. KableMan
    KableMan
    Feb 9, 2005
    610
    Solihull
    +87
    Hey DLPmaybe - check out this thread too as it specifically talks about setting up the SP50 with DVI/HDMI.
    http://www.avforums.com/forums/showthread.php?t=211977&highlight=sp50+powerstrip
    I only have a VGA Monitor and I was able to use powerstrip (and even without it to a certain extent) to get a display on the Samsung. If you don't have a monitor at all the sp50 will support all the standard resolutions 800x600, 1024x768 as well as 1280x720 so you shouldn't have any problems :thumbsup:
    KableMan
