Samsung SP50 Connections etc..
Discussion in 'Televisions' started by BillyTheDad, May 3, 2005.
  1. BillyTheDad
    BillyTheDad
    Apr 16, 2005
    30
    :confused: Am getting the Sammy Sp50 but wanted to know what is the best way to connect up my Sky+ and dvd players to it. New to all this so help would be appreciated. cheers. :confused:
  2. Razor
    Razor
    Dec 15, 2004
    37,547
    2
    +12,504
    Sky should be connected via rgb scart and your dvd player if it has a dvi/hdmi connection you should use this. If not connect via component connection.
  3. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
    what he said ^^^
    i nhave my sky connected by scart rgb monster cable (cos i got it free) and my dvd player by component. got my component cable from here www.cableuniverse.co.uk very good quality cables at very cheap prices. if u have hdmi /dvi on ur dvd player then use that.
  4. g_unit
    g_unit
    Jan 4, 2005
    102
    16
    Don't cheep out on the cables - I had crappy scarts connecting my stuff to the Sammy and pq was ok.
    Got some Thor scarts from Maplin on special offer (£20), these had a significant improvement in clarity, sharpness and colour over the old cables.
