samsung sp46l6hx - shadow on bottom of screen
Discussion in 'General TV Discussions Forum' started by cyberdaz, Jul 17, 2005.
  1. cyberdaz
    cyberdaz
    hi ive the samsung sp46L6HX and ive noticed what appears to be a darkend band across the bottom of the screen (about 1 inch high) its visable in all scart feeds (i tried xbox )
    ive also looked at some of my settings but none seem to help , is it a lamp alignment problem (if such a thing exists ?)
    incuded is a pic ..
    BTW ive noticed the band for about a week and cannot remember if i saw it on day 1 tho.
    thanks 4 help
  2. Hartigan
    Hartigan
    Jul 8, 2005
    232
    Middlesbro
    No expert here, but that does look to be a problem. During my time in retail I did notice similar problems on older CRT rear projection screens and that was down to mis-alignment, but I'm not sure if that can be the case here. Would be my first guess too though.
    Get it checked while its still new and get a replacement.
  3. cyberdaz
    cyberdaz
    thanks , also as no expert i thought the same , anyone else know if this is the likely problem ,and would i be able to rectify it myself - ive no exp' of rear Projection tellys and im asuming that i can re-insert the lamp properly - or am i barking up wrong tree ? (as im not looking forward to taking back set and wait for replacement if at all possible)
    thanks !!!
