Samsung SP46L6HX or wait for Toshiba 46WMT58?
Discussion in 'General TV Discussions Forum' started by Nidge, Jul 26, 2005.
  1. Nidge
    Nidge
    Mar 5, 2005
    26
    3
    So I've been thinking about buying a DLP TV for some months now. Was originally going to go for the Toshiba 46WM48 but got put off by the bad reports on here. My question is: Is it worth waiting for the replacement model for this set from Toshiba (46WMT58; HD4, 2x HDMI, integrated Freeview tuner, due August/ September, cost???) or should I go for the new Samsung SP46L6HX?
    Anyone any thoughts?
  2. lochindaal
    lochindaal
    Nov 21, 2003
    138
    From a quick scan on the web the down side of the Tosh for me is the large speakers on the side. It says a slim bezel for the larger models, why don't thry do that for the 46"
  3. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +251
    Of course, if you wait for the Toshiba, then by September they'll probably be another new TV available soon or just announced, for example the Samsung 1080 models. Unless 2 HDMI sockets is important to you, then I'd go with the Samsung. The specs look very similar to me.
  4. Nidge
    Nidge
    Mar 5, 2005
    26
    3
    Thanks. I spoke to Toshiba today about the 46WMT58. They told me that it was now tentatively due in October and would cost at least a couple of hundred quid more than the current model. I can't wait that long, nor do I want to pay more than is necessary so I've ordered the Samsung instead.
  5. maidstoneman30s
    maidstoneman30s
    Apr 21, 2004
    155
    16
    not in maidstone, hehehe
    Hi there,
    Any one got any info I can read up on for the Tosh46WM58.
    Got the 46WM48P. My 2nd one now. so looking for alternatives
    Kind regards
    maidstoneman30s :smashin:
