Samsung SP46L6HX - Best TV I've ever purchased
Discussion in 'TVs' started by Tarbat, Aug 31, 2005.
  1. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +252
    Well, we've had our Samsung SP46L6HX TV for exactly one month now, and have to say it's lived up to all expectations. It's had a lot of use over that month, clocking up a total of 151 hours according to the lamp counter, so that averages 5 hours per day!!!
  2. knightsyr
    knightsyr
    Jul 6, 2005
    73
    ive had mine about same time whers the lamp counter also impressed woith it . one thing on pip the smaller box is a lot better pq than the screen is yours the same and what are your sttings
  3. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    +252
    Lamp counter is in "14 OPTIONS" in the service menu.
    Settings - Mode = Standard, DNIe ON, Contrast 80, Brightness 57, Sharpness 20, everything else 50. But best to use something like the THX DVD tests to setup your TV. Also following discussions on the US forums, I've turned GAMMA down to 1 in the service menu.
    BTW, the Service Menu on these TVs is accessed by pressing INFO - MENU - MUTE - POWER in quick succession when the TV is in standby. Use at your own risk!!
  4. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    cjgpers :hiya:
    Glad you're loving the sp46, have to admit that after 6 months of having my sp50 im still impressed by it, not had a look at how long the bulbs done, will have to check, im sure getting in to the service menu is the same. :smashin:
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,944
    2
    +3,311
    Quick if odd question.
    Is that stand integral to the set? There appears to be a gap between the set and the speakers rather than between the speakers and the stand?
  6. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    +252
    The stand is separate, but cleverly designed to make it look like the speakers are part of the stand, with the screen floating above the speakers. Samsung call this their "floating screen" design, made to look more like a plasma or LCD TV.
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,944
    2
    +3,311
    Clever indeed. Its important for me really because I don't use the supplied stands and the Sammy would have fallen at the first hurdle if the stand was integrated.
    ToF
  8. Dazzyman
    Dazzyman
    Aug 30, 2005
    1,072
    North Yorkshire
    +88
    Im going to look at seeing one of these in person on monday to check whether Im up for DLP's if I am its the unit Im most intrested in!
  9. knightsyr
    knightsyr
    Jul 6, 2005
    73
    why do you say use at own risk and why is the acces to service menu not in my dlp booklet.
    also what is gamma 1 never heard of it .
    :thumbsup:
  10. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    The service menu is supposed to be used by service engineers only, not really for consumer use. That's why you need to know what you're doing if you're going to mess about with settings here and is also why it's not mentioned in the user manual.
  11. knightsyr
    knightsyr
    Jul 6, 2005
    73
    have you changed your gamma control and is it worth it am i risking wreacking the set . if so i leave well alone
  12. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    There's little point in messing about in the service menu unless you know for sure that any changes will work for you personally. Gamma correction, for instance, changes the overall brightness and contrast of an image but if you're happy with what you can achieve using the standard TV menu and if you're unsure of what you're actually doing in the service menu then I would leave well alone.
  13. Lion
    Lion
    Jul 13, 2004
    1,682
    Derby
    +160
    the important thing if you want to play with the settings in the service menu is to write down the original factory settings before you change anything,
    that way you can always put it back how it was if it all goes horribly wrong. :thumbsup:
  14. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    2,795
    +440
    How many of the scarts are RGB?
  15. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    Two.
  16. malso
    malso
    Mar 24, 2005
    278
    16
    yes and it looks great too, the HLR 67'' 1080p looks similar too; just miles bigger :eek:
