Samsung SP46L3HX - 3 blinking lights problem!
Discussion in 'General TV Discussions Forum' started by ianrog, May 3, 2005.
  1. ianrog
    ianrog
    Hi Guys,
    I bought my DLP set ( Samsung SP46L3HX ) on the 23rd February 2005 and after 48 days of purchase, I am facing a horrible nightmare with my set. When I turn on my set, the green lamp starts to blink and after a minute or so, my set will have 3 blinking lights ( TIMER , LAMP , STANDBY ). Sometimes when the green lamp indicator blinks , the T.V set will turn on but this will not always occur.I am very disappointed since I used my set only in weekends.
    Does anyone faced this problem?!? :eek:
    Regards
    Roger
  2. philip41
    philip41
    Feb 7, 2004
    237
    16
    Sussex
    According to the manual, it is telling you that the bulb needs replacing,what the fudge, i would contact whoever you bought the set from and let them know.
    Has the set shown any other symptoms, ie the screen getting a bit darker than usual.
  3. Razor
    Razor
    Dec 15, 2004
    37,615
    2
    +12,442
    There will be a way to find out how many hours the bulb has been used for, its usually via a engineers service menu. If you could access that you will know a bit more history of this set. Was it purchased as new or exdemo/second hand?
  4. ianrog
    ianrog
    No other symptons. I`m quite confused if the bulb needs to be replaced since the bulb still works.
  5. ianrog
    ianrog
    I tried to access the service manual but it wont show up and I bought my DLP set as new.
  6. Razor
    Razor
    Dec 15, 2004
    37,615
    2
    +12,442
    I would personally get an engineer out asap and identify the fault. If it has loads of hours clocked on the set, I would kick up a fuss and reject it. Ask for a replacement or refund.
    A few members have got good results armed with a copy of the sale of goods act.
    Good luck :thumbsup:
  7. supermackem
    supermackem
    Feb 20, 2005
    2,151
    sunderland
    +78
    Wow anyone noticed the influx of people posting about the sammy of late. Its a shame as i was going to recommend this tv to my uncle, think ill tell him to hold back a few months for the new sets to hit the stores.
