Samsung SP46 Fault
Discussion in 'General TV Discussions Forum' started by vigalent, May 29, 2005.
  1. vigalent
    vigalent
    Mar 7, 2005
    89
    My SP46L3Hxx has just developed a fault.
    When you try and switch it on, it continues to goes through what appears to be the normal power/warm up cycle. I get no picture/sound, and can hear it starting/stopping the colour wheel continually.
    Anyone else had this problem before or is it time to call an engineer.
    BTW If I call and engineer, is it better to go through the place I brought it or just call Samsung direct?
  2. JZEE
    JZEE
    Jan 8, 2005
    Vigalent,
    You probably have a defective lamp ballast - its a known problem on this model - you should definitely call for service.
