Samsung SP L6HX - What should I hook it up with?
Discussion in 'Televisions' started by rushers, Aug 20, 2005.
  1. rushers
    rushers
    Mar 30, 2005
    After months of trolling :devil: reviews, this site and AVS forum for months I have finally decide to go with this baby. I am setting up an entertainment room and while ideally I would have got a projector the room has far too much ambient light which is difficult to control.
    I am starting from scratch and have no other kit, so what should I add to make this set sing :D. I decided to get the display and then try and build around this.
    -HTPC? If so what
    -Scaler? HTPC sounds better bet than scaler, esp wrt cost.
    -DVD player? I had been looking at Denon 1910/Panny S97.
    -AV processor? I had been looking at Denon 1905/2105 or Yamaha RX-V650.
    Any suggestions
