Samsung SP-50L7HX - Green Pixels and banding?
Discussion in 'General TV Discussions Forum' started by shak, Oct 25, 2005.
  1. shak
    shak
    Jan 28, 2004
    28
    3
    London
    After reading as much as I could from this lovely forum I decide to take the plunge and upgrade my 28" Wega for 50" Samsung.
    Received the TV from Currys on Sat however after playing with it for a while I discovered green pixels flickering on the screen. The seemed to go away on its own. Afterwards it was back with a vengance and also with (as I can only describe it as) banding effect ie colours are not graduated (does not blend together and instead are quite abrubt changes??)
    Help me please as after taking so long to chose the silly thing I don't want to give it up :(
    Thanks for all your help
    Shak
    PS If it is helpful the TV is connected to -
    DVD - Sony DVP S7700
    AMP - Sony DB 930
    Speakers - Mission 77 Series & BK XLS200
    Pioneer Freeview Box (old one with ONdigital logo on it!)
    I know it is not very up to date compared to other people's system but I like everything :)
  2. kmhtkmhtkmht
    kmhtkmhtkmht
    Someone else had this same problem, look a few threads back.
  3. shak
    shak
    Jan 28, 2004
    28
    3
    London
    I have used the Search as many times as possible and have found a few similar problem but it then did not give a solution.
    I did wonder as first if the TV just needed time to be run in?
    I will look through the threads again in case I have missed any.
    Shak
  4. Tarbat
    Tarbat
    Oct 15, 2003
    2,592
    Easter Ross, Scotland
    +303
    On what type of source are you seeing colour banding? If it's from Sky, Freeview, or Cable, then blame the source. HiDef TVs are very good at showing all the defects in a source. Test with a DVD, or even better, a HiDef source and see if the problem dissapears.
