M
mucwhore
Since one week I have a Samsung SP46L5HX. Wanted to post my first impressions and a question.
First the question: I cannot enter the service menu. The combination MUTE-1-8-2-POWER while in stand-by does not work for me. As soon as I press the '1', the TV switches on, and even though I press the remaining keys, it only comes up with the normal TV picture. Any ideas?
Now my impressions about the TV:
1. You can and will notice the fan (or mine is damaged) in your silent living room. Even 4 meter away.
2. The reaction to the remote is slow. Channel switching is slow. Time from Power-On to picture is fast (<10s) (manual says 25s).
3. Analog cable TV tuner seems to be quite good. Sure, there is picture noise, but not as bad as seen on other TVs this size (compared at the dealer).
4. DVD picture is sharp and colours are nice (via RGB, DVI not tested yet). Black level is not the best compared to my old CRT, but gray tone separation is good (on the dark _and_ on the bright side). Occasionally I can see pixel noise on certain dark grays. Internal de-interlacer works quite good (verified with Test-DVD).
Overall it is a fine and stylish set if you can live with the LCD-typical grayish black-level and the fan noise.
-Dirk
-Dirk
