Samsung soul -dark/bright screen fault
Discussion in 'Mobile Phones Forum' started by deanof, Jun 14, 2009.
Tags:
  1. deanof
    deanof
    Jun 14, 2009
    I have a samsung soul that was working fine up until today when I looked at the phone and couldn't see the screen. It hasn't been dropped (recently), banged or wet and works fine other than the screen is extremely hard to see because it is so bright/dark (I'm not sure which!).
    I have tried a master reset and flashed it to check if it could be the software but has made no difference. I therefore thought I would try this site to see if anyone has had a similar problem and knows how to sort it or do I need a new screen?
    I appreciate any advice given,
    Many thanks,
    Dean
