Quantcast
Samsung SMT-S7800 Network Help Please
simon66
Hi all! I hope somebody may be able to help.
After several hours of frustration i still cannot get my SMT-S7800 to connect with my BT Home Hub 3 via ethernet cable.
I know the cable is ok as a laptop connects to the home hub no problem.
In the samsungs settings i have tried the automatic network function but it says there are network problems.
In the home hub settings screen the samsung does not show up as a connection although everything else does.
I also tried to enter the samsungs network settings manually (copied from ipconfig/all on a ethernet connected laptop).
Any help or pointers in the right direction would be gratefully received.
Many thanks in advance.
Simon
logiciel
