Samsung SMT-S7800 FreeSat HD Digital audio skips on recording
Discussion in 'Digital TV & Video Players & Recorders' started by Adamskicox, Jan 5, 2012.
Tags:
  1. Adamskicox
    Adamskicox
    Dec 14, 2011
    I bought the SMT-S7800 about 3 months ago to replace SkyHD. Everything is working well except for the audio replay on HD channels which have Dolby Digital sound tracks. When either replaying from a recording or playing after pausing, there is a glitch in the audio stream every 10 seconds or so. As its a digital stream, the break is very obvious and very annoying. It's such a shame as everything else is top quality. I have several other sources which play Dolby Digital at much higher bandwidths so I'm pretty sure it's not my Denon AV Amp.
    When watching live TV, the audio glitch is not present.
    Incidentally, the audio glitch is the same when playing audio through HDMI and Optical.
    Any ideas or does anyone else have this issue?
    Cheers.
  2. h107474
    h107474
    Feb 21, 2012
    7
    3
    I have the same issue so I doubt its your amp. I have mine outputting HDMI to my TV.
    Recordings from some HD channels have sound drops every 10 seconds or so. Live HD channels are fine. I haven't looked in detail regarding DD but I will check it out. Now we have two confirmed users with this issue there must be more.
