Samsung SMT C7140
Discussion in 'Digital TV & Video Players & Recorders' started by Chr1s, Sep 7, 2012.
Tags:
  1. Chr1s
    Chr1s
    Sep 7, 2012
    This is a DVB-C box for use with cable in Portugal. All tuned in & receiving programmes but no EPG. All I get is the channel list. My Samsung TV does receive the EPG so I know it is available. Cable here is not encrypted so I don't have a smart card. Box says signal strength is approx 60% but I get HD on my set and the box with pretty good quality. Don't fully understand how EPG works but I assume received as a data package of some kind. The Samsung has no option for setting time manually so no EPG means no date/time which means no recording. The cause and solution is out there, just that I can't find it. Any suggestions appreciated.
    PS Already done re boots, factory reset etc
