Samsung SMT-2100C Scart Hell
Discussion in 'Satellite TV, Sky TV & FreeSat' started by chrism1966, Mar 23, 2005.
  1. chrism1966
    chrism1966
    Mar 23, 2005
    3
    Im new to this forum, but i hope someone can help? Im trying to connect a samsung 2100 ntl cable box, pioneer dvd recorder, LG Vhs VCR. Im in scart hell :mad: cant seem to get them the right way round to work correctly, no instruction book with samsung does not help? :lease:
  2. chrism1966
    chrism1966
    Mar 23, 2005
    3
    any good web site or can anyone help?
  3. Boy Lex
    Boy Lex
    good luck - as soon as you start trying to use a vcr and a dvd recorder you'll get in trouble. Try feeding ntl into DVD, DVD into TV and you should be able to have the digibox 'passthru' the DVD. That is to say that you can record ntl on the DVD recorder and see it on the telly - even if the DVD recorder is switched off.
    Then... feed the VCR into a spare connector on the DVD recorder. You can watch videos by switching channels on the DVD recorder when it is on. You will not be able to record ntl onto the video, nor will you be able to copy DVDs to video. This is the simplest way to do most things tho.
  4. chrism1966
    chrism1966
    Mar 23, 2005
    3
    thanks ill give it a go!
