been annoying me for weeks this has and i have only just found out what the problem is
basically i have a samsung sct-2100c connected to my samsung LE37M87BDX via scart cable
for weeks i have been having problems changing the channel on the cable box, thought there was a problem with the box as i had to put the remote right next to the box to get it to change channel (very annoying
), tried batteries in remote and checked cables etc
now i have just realised that when the television is on standby the remote changes channels absolutely fine, thought i would test it and sure enough when the tv is on it struggles to change channel at all, tried it umpteen times now and this is the problem
is this a known issue as it looks to me the two are conflicting with each other maybe because they are both samsungs
can't get the tv remote to control the cable box either tried lots of codes and it won't work
has anyone got a solution or could give me advice on where to go from here as it's driving me nuts
Cozy
Cozy
