Samsung SmartTV - automatic switch to HDMI source when turned on
lafaki
We have a ue55ru7475 model and I would like to enable it so that it automatically switches to an HDMI source when input is detected i.e. input device is turned on.
Is that possible?
Our older Panasonic TV model supports this functionality by default.
When searching in internet, I have only found some articles about the HDMI Consumer Electronics Control (HDMI-CEC) standard.
Regards,
Akis
zeppelino
Go into General settings - smart features - enable autorun last app.
May be slightly differently named as I have a 2017 Samsung.
lafaki
I have already done that and it works fine.
What I want is that e.g. when I switch on an HDMI device while watching live TV, the TV to change input source from live TV to that HDMI source that just turned on.
cuke2u
I think most tv's are setup to control the device these days not Visa versa...
lafaki
Well, I have found this post
This seems to be the opposite of what I want
JayCee
HDMI CEC doesn’t always work with different brands (and often the same brand) of equipment.
zeppelino
Sorry, I misunderstood your query.
Turn off hdmi cec on both devices. Turn both off and unplug the hdmi cable. Plug it back in after 5/10 minutes and turn on both devices. Flick cec back on - if that doesn’t work then you’ll have to do things manually as there’s no set standard for cec.
lafaki
Thanks all for your reply.
I applied the above steps and the HDMI source auto switch did not work again.
The device connected via HDMI is PC.
Regardless of the support for HDMI CEC, the TV is aware of the state of all connected devices i.e. On/Off state is shown on the device icon.
Auto-detect seems to work, the functionality that is needed is the auto-switch.
lafaki
The way I'm reading it is the OP wants his TV to auto-switch to the HDMI input his PC is connected to when the PC is turned on.
Yes, this is right :)
My old Panasonic TV from 2011 supports that for one out of thevthree HDMI inputs.
It is quite handy when turning on the PC while watching TV.
cuke2u
Then I don't know, I would have thought though, as the pc does not support cec, it will not send the necessary info to the tv?
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
