Question Samsung Smart TV and Humax Freeview Recorder
Discussion in 'General TV Discussions Forum' started by CrazyRach, Jul 14, 2015.
  1. CrazyRach
    CrazyRach
    Jul 7, 2015
    4
    4
    Manchester
    Hi There,
    I've just got rid of sky tv and decided to start using my humax hdr-fox t2 again. Its the first time I've had it plugged in my Samsung Smart TV.
    When setting the TV up with sky, it would ask if I was using an STB and what area I was in ect. After doing all that, if I wanted to use the voice commands while watching sky it would find the channel on sky and select it.
    Now on my humax box, if I use voice commands, it takes me to the samsung freeview channels rather than the ones on my humax box, which can be a bit annoying and confusing.
    Does anyone know how to change this?
    Any help appreciated.
    Kind Regards,
    Rach
  2. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    Do you maybe have to go through the TV's setup procedure again and tell the Tv the type of STB connected?
  3. CrazyRach
    CrazyRach
    Jul 7, 2015
    4
    4
    Manchester
    If you go through the stb procedure it only asks for satellite or cable. There's nothing for a pvr box. apparently you just have to do it through ariel
  4. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    Guess you'll just have to select the Humax the old-fashioned way then :)
  5. salsa
    salsa
    Apr 25, 2008
    my menu gives me the choice of air for freeview channels or freesat,so I can change,dont know if thats what you are meaning
