Samsung smart remote wont output IR after the TV turns on?
Crushbam3
After checking with my phone camera i can see that the remote that the remote that came with my samsung S95B tv outputs IR when the TV is turned off but once it turns on it stops, this isn't an issue when it comes to controlling the smart tv and nvidia shield but my sky+hd box only works with IR and i've also gotten it to work with this remote just not while the TV is on does anybody know a fix for this? any help appreciated
notengo13
You need to pair first your RC with "back" button + "play/pause"
Upvote 0
Rudzki
The smart remote only outputs IR once to turn the TV on, the rest is Bluetooth.
Upvote 0
Crushbam3
I've gotten it to work with IR while the tv is on and paired. I went into connected devices, universal remote, and pressed add cable/satellite box. I then put my service provider as BskyB but i dont think that's really necessary you can pick any i thin but not sure. Then when prompted to test if the cahnnel changes you try twice and it will fail both times, from the third attempt onwards a message pops up saying "check your box is set to receive IR" and the remote is now outputting IR and working
Upvote 0
Samsung QN800B 8K TV Review
