Samsung SM2333HD - 23" Full HD TFT Monitor with Freeview - £179.99 @ Amazon
bingsy
Samsung SM2333HD 23 inch Wide 5ms 1920 x 1080p HD: Amazon.co.uk: Electronics & Photo
Wasn't sure wether to put this in Electronics or Computer section.
Product Features
  • Dynamic Contrast 10000:1 for Vivid Colours
  • Built-in Digital TV Tuner Picks Up Freeview
  • Innovative Power Saving Facility Saves Energy and Money
  • 2 x HDMI Sockets Connect to your Camcorder, Blu-Ray Player or Games Console
  • Colour Effect Function Lets You Add Tints to Viewed Photos
Technical Details
Screen Size: 23" Widescreen
Resolution: 1920 x 1080
Brightness: 300 cd/㎡
Contrast Ratio: DC 10000:1 (1000:1) (Typ.)
Response Time: 5ms
Viewing Angle (Horizontal/Vertical): 160˚/160˚ (CR>10)
Colour supported: 16.7M
Video Signal Input: Analog RGB, DVI, HDMI, Component , TV (Digital TV / Analog TV)
Sync. Signal Input: Separate H/V, Composite
Connector: 15pin D-sub, DVI-D, 2HDMI, Component, DTV Tuner, Optical Out, Scart, CI Slot
Power Consumption: 55 watts
Standby Power (DPMS): <2 watts
Plug & Play: DDC2B
Multimedia Speakers: 3 watts x 2 Ch
Optional Accessories: Remote Controller, D-Sub Cable
Special Features: Built-in DTV (DVB-T) Tuner, Component, 2 HDMI, CI Slot, Full HD
USB powered hub option: No
Mac compatibility: Yes
Wall-Mount: VESA 100mm
Cabinet Colour: High Glossy Black
Product Dimension (With stand, WxHxD): 558 x 415 x 219mm
Product Dimension (Without Stand, WxHxD): 558 x 364 x 74mm
Shipment Dimension (WxHxD): 631 x 434 x 141mm
Product Weight: 6.1kg
Shipment Weight: 7.95kg
Stand Function: Tilt
Type: Simple
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
