Samsung SM225MD vs. LE22S86BDX - Opinions wanted
Discussion in 'Samsung TVs Forum' started by ntisdale, Sep 20, 2007.
Tags:
  1. ntisdale
    ntisdale
    Sep 20, 2007
    There seems to be some information/reviews out there on the samsung SM225MD (or at least it's analogue counterpart the SM225MW) but little information on a very similarly spec'ed set samsung's LE22S86BDX (see http://www.play.com/Electronics/Ele...descreen-LCD-TV/Product.html?searchtype=genre).
    I considering both of these primarily for use as a TV for in the bedroom but would like PC connectivity for use with a HTPC. As mentioned both set are similarly spec'ed, the LE22S86BDX however is classed by Samsung as a TV whilst the SM225MD is classed as a monitor with TV tuner. I don't know how significant this is in terms of their function but in terms of styling the LE22S86BDX is definitely more TV like.
    If anyone has experience with either models I would be keen to hear them. As far as I have found from searching this forum, the web and samsung's user manuals the main complaints of the SM225MW (and so I assume they apply to the SM225MD) is poor sound and bad standard definition picture. I believe the SM225MD has SRS trusurround - I wonder if this improves the situation? Also I would be keen to hear people's opinion of the picture quality from the internal digital tuner or from an RGB SCART source. The LE22S86BDX seems to include a few extra image processing buzz words like DNIe etc... does anyone know if this helps improve the quality of standard def pictures? Finally I get the impression both the SM225MW and SM225MD cannot receive sound over HDMI, the manual states you need to connect a seperate audio cable into the 3.5inch audio in jack, is this true?
    Neil
  2. j633295
    j633295
    May 2, 2005
    I have bought the SM225MD mainly used as a PC monitor and am really pleased with it. The SM225MD is positioned as a LCD monitor whereas the LE22S86BDX is more designed as a TV set. It is slim and space saving. As for the sound quality, don't expect it to be great (given its slim design).... I don't expect them to be good from any LCD monitor anyway. I use the audio in jack to connect from PC sound card to the monitor.
    Hope this helps.
  3. airefc
    airefc
    Oct 12, 2007
    98
    Hi I have been considering buying the Samsung LE22S86BDX, however I cant find any reviews on it either.
    Dont want to buy it without seeing any opinions on the tv as its not worth the risk.
  4. Dunk1970
    Dunk1970
    May 4, 2005
    71
    +5
