SAMSUNG SM2032BW 20" WIDESCREEN TFT MONITOR for PS3?
Discussion in 'Samsung TVs Forum' started by munday63, Sep 14, 2007.
Tags:
  1. munday63
    munday63
  2. xanthor
    xanthor
    According to Samsung's site, it has HDCP support, so as long as you have a HDMI to DVI adapter it should be theoretically possible...
    ..in practice. Not sure. IIRC, Some people have had problems connecting the console to HDCP compliant monitors.
  3. munday63
    munday63
    Thanks for your reply.
    Can anyone recommend one for under £200 that would be suitable?
    I thought samsung were one of the better makes for a screen?
