JohnMatrix
Hi, I just purchased a brand new Samsung LA26A336 and I'm having problems with Ghosting images whilst playing Fifa 09 through my PS3. I'm looking for advice on whether there is anything I can do to fix this or whether I should return the TV and look for a different model. Here's a link to the specs of the LA26A336:
26" HD READY LCD TV LE26A336 - LCD - television | SAMSUNG
I currently have my PC set up to go through the TV with an HDMI cable (was £10) and have tested:
Command & Conquer: Red Alert 3 - shows some slight ghosting when panning rapidly through the map but only the kind of ghosting that I would expect from an LCD TV, the game is still perfectly playable and looks good.
Call of Duty 4 - No ghosting at all and looks amazing!
For general PC use (Internet Browsing etc.) the display is fairly good, not perfect but I don't think you can have a PC running perfectly through a 26" LCD TV.
Then on to the PS3 which I'm having problems with. I've tried this both on 1080p (which still displays on the monitor) and currently on 720p with a different HDMI cable of the same model as the PC is connected with:
Virtua Tennis 3 - Good, only very slight ghosting when the characters are running/diving.
Grand Theft Auto 4 - No problems with this apart from Anti-Aliased lines but I'm pretty sure these are the PS3's doing.
Dead Space - No ghosting during my quick test of the in-game scenes but the opening cutscene didn't look too great. There was a lot of flickering on a distant Space Ship and when light shone on a characters head the shadows cast were quite blocky. Not sure if this is due to the PS3 and the game or that my settings need tweaked
FIFA 09 - This is the main problem. A still image of the game would look stunning but when I start to pass the ball about and the camera follows I get some bad Ghosting effects around the players. There is about a 1cm trail left behind every player and the effect can be quite nauseating. I also tried the PES 2009 demo (another football game) and there is still a fair bit of ghosting but not quite as bad as FIFA shows.
Here are the current settings which I have played around with a bit and no matter what I do I can't get rid of the ghosting effect on FIFA.
Mode: Standard
Backlight: 7
Contrast: 95
Brightness: 50
Sharpness: 35
Colour: 60
I'm happy to try out any settings you can suggest but it looks more likely that I might either return the TV (I'm still within the 14 day return period) and look at a different model or call Samsung and see if they can recommend anything or if I can maybe get them to replace the TV with a newer model.
If it comes to that can anyone recommend another 26" TV in the £300-£350 price range that I might look at. What would be the main things I would look to improve to get rid of the ghosting? A TV with 100Hz mode and a faster response time than 8ms would be a start I presume?
Mode: Standard
Backlight: 7
Contrast: 95
Brightness: 50
Sharpness: 35
Colour: 60
