Samsung SD-DVD440
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by dippy9876, Dec 15, 2004.
  1. dippy9876
    dippy9876
    Dec 11, 2002
    20
    hack for samsung sd-dvd440 1. Power on the system with an empty tray, it will display "No Disc".
    2. Press the SUBTITLE key and then press 57538. It will display the current region setting.
    3. Select the desired region setting (9=region free, 1=region 1, 2=region 2, ...).
    4. Confirm the choice by pressing the SUBTITLE key
  2. geri_leejoens
    geri_leejoens
    hey dippy9876, or anybody else who could help me out of this:
    is this hack / code that is described above, also usable on
    SAMSUNG SV-DVD 540 ?
    because that would be the only one that is available in Austria at the stores
    thanks for your help :D
