Samsung S8 Cases & Screen Protectors
chaz206
So people, ive finally got 1 of these lovely phones but having a few probs deciding on the correct case and more importantly a screen protector
Becuase of the job i do, the phone def needs both really cause of general building site crap going on it
Case wise ive got a couple that came with it which i can use but at the mo the spigen neo hybrid and the rugged armour look good
Now screen protector wise i am confused as hell, as there are a lot of conflicting stories weather certain ones work with the cases
Any reccomendations plz
Also if people just want to post pics of their phones up or their cases that would also be good
cheers
chaz206
I use a spigen case and tate screen protector, both fit really well and are inexpensive.
Spigen Rugged Armor: Samsung Galaxy S8 Case, Spigen® Galaxy S8 Case Cover: Amazon.co.uk: Electronics
TATE GUARD Galaxy S8 Screen Protector: TATE GUARD Galaxy S8 Screen Protector: Amazon.co.uk: Electronics
cheers mate, ive also been looking at the spigen case over the neo-hybrid.
At the mo ive got a red canary case that came with the phone.
Cant find anything ion the screen protector its unavailable and cant even email the company, reviews wise its got a lot of good ones so i'll see if it comes back
Anyone else?
chojin
I normally use a Spigen tempered glass protector but the reviews and the fact it fits with the case swayed me, it's been on for a couple of months now it's very good.
Jowsey
I'll be looking for the a case and screen protector for an s8+ very soon so I'm following this intently :)
chaz206
honestly mate it is like the hardest thing in the world to find a screen protector for these phones lol
plus dont know why buy a lot of people arent posting to give any advice. im on a few other forums and theres a lot more info there, mostly in america though
chojin
My tate screen protector has cracked after a few months, really disappointed as it sat really well on my phone along with the spigen case... so I'm now on the hunt for a replacement.
Jowsey
It is eerily quiet in here...
Loving my new S8+ so far but I am concerned at how slippy it is!
Think I'll end up with a DBrand style skin on the back and a yet undecided screen protector. Think I'll just have to take a dive with one from Amazon!
chaz206
Have you contacted tate, as I can't seem to find them in the UK
I'm leaning towards ordering a ringke clear fusion case and it looks hard on the back soft on the sides and a bit of lip on the front
Then again the back might be slippery so need to see
The spigens which I used on my s4 and that are good but the neo hybrid puts a lot of bulk on the phone I think and the rugged armour looks crap from the back lol
chaz206
Let me know which one you get mate I'll post a link up of someone on another forum who got one from Amazon I might be getting that one
chojin
I'd not thought of contacting Tate, I'll look into it. I forgot to mention the Tate guard came with a carbon fibre effect protector for the rear of the phone which was a bonus.
I love the spigen case, it's light and doesn't add much bulk, has a slight lip so if the phone was to be placed screen down it wouldn't actually make contact with the screen.
I originally had this case: Samsung LED View Case for Galaxy S8 - Black Samsung LED View Case for Galaxy S8 - Black: Amazon.co.uk: Electronics
What a massive waste of money and it split within a couple of weeks.
chojin
I have just ordered this one for my S8 and it is near identical to the Tate Guard I have fitted at the moment, it will be here tomorrow so I can confirm then.
They also do a version with a carbon effect back sticker which is what I received with the Tate Guard: https://www.amazon.co.uk/dp/B06VX9ST57/ref=psdc_329083031_t1_B071WJF7KL
chojin
Seems to be identical to the kit I received with the Tate Guard, will install and post a picture and comments shortly.
chojin
Installation was a breeze just don't use the supplied dry wipe it leaves fibres on the screen which makes more work removing before you drop the protector on.
Jowsey
Think I'll end up pumping for that. Already suffered some fall damage on my S8 Plus :(
Just a couple gentle nicks that could have been avoided if I had a small amount of protection.
chojin
Update, noticed a slight loss of sensitivity when swiping from the top of the screen, must be due to the cut out, only minor but it will do for now.
Jowsey
Noted, thanks!
I'm currently getting the screen clicking problem due to the glue for the screen very intermittently. Will nip into my local Samsung shop to see what the best course of action for this is.
Whilst I'm simultaneously starting a warranty claim with LG for screenburn!
I have all the luck!
chaz206
damn was looking forward to this protector being good. i might order the glass version and see how it fits and feels.
Also what case have you got mate?
Noted, thanks!
what glue do you mean mate, the one that came with the protector?
chojin
This is a tempered glass protector, the reasonfor the loss of sensitivity at the top is due to the thickness of the protector, there is no loss anywhere else.
I have the spigen case that I linked in my first post, it's the rugged armour, fantastic case, adds little bulk and looks nice too.[emoji106]
Jowsey
Nah. It's the phone itself. The glue between the glass and the screen I believe. It sounds like the glue isn't holding it tight so it comes slightly loose every now and then.
The next time I grab it it'll come free of the surface and making that SCHTCK sound.
Yet to go for a protector as I'm just keeping an eye on my phone at the moment to see if I should return it.
davidhen
Glass protector never go well with the curved screen, so a normal plastic protector should work fine which has fine cut out for all the speaker and sensor openings. Talking about protector and your work demands, Slim armor should be the one that you should go for, wont add much bulk and will 360 protect your phone.
chaz206
Def return it mate, that sounds bad (to me anyway), £500+ phone and this happens
starting to think the same thing mate, just get a film protector. i have yet to see a good review of a glass version staying on
which slim armour do you mean, cant find one for the s8
