Samsung S224 - At last a region hack that works :)
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by fishyben, Jul 21, 2002.
  1. fishyben
    fishyben
    press repeat (not repeat a-b) then type in on remote 57538 a number will apear on screen which is the current region code. then press 9 then press open and wait 15 secs press off on remote - this will make the player multi region :) it worked for me- have fun
  2. redmondbarry
    redmondbarry
    I know i shouldn't take up an old thread like this but i really urge to know if the samsung S224 can read region 0 dvd with ntsc code.
    Thanks in advance!
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    36,567
    Bristol
    +9,377
    No reason why it shouldnt as Region 0 means no region coding and NTSC is just a picture format so even if your TV cant handle NTSC the Samsung should be able to convert it to PAL50hz so it will playback fine.
  4. redmondbarry
    redmondbarry
    thanks a lot!
