Samsung Remotes
I just purchased a Samsung Q32Q60AAFXZC TV because I thought my old TV (Samsung LN32B460B2D) was failing.
Turns out it just needed a reset so I took the new one back.
I have a question about the new style Remote
The new style Remote leaves a lot to be desired.
My old Remote has buttons for just about anything, including Picture Size, which I can change on the fly just by pressing it.
The new Remote has very few buttons and to change the Picture Size I have to press several buttons and navigate the on-screen menu.
I don't find it very convenient at all.
Does anyone know if my old Remote is compatible with the new TV?
It would be much more convenient if I could use the single buttons on the old remote instead of scrolling through multiple menus to do just one
simple thing.
I should have tried it when I had the new TV.
notengo13
It should be compatible because is IR, but not all buttons from your old remote will work with new tv. New remote is cool just you need to learn some functions Doble press button etc...
logiciel
