samsung remote code for toshiba HDDVD EP30
Discussion in 'Home Cinema Control & Remote Controls' started by wezza2, Jun 9, 2008.
  1. wezza2
    wezza2
    Jan 14, 2008
    15
    Hi all plaese can some one help me i have looked all over the net for the code to control the toshiba HDDVD EP30 with my samsung remote but i have had no luck can anyone help
    ps the samsung remote is a BN59-00603A
  2. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    This remote isn't intended for controlling DVD players, is it?
    Have you posted in the EP30 thread under HD Players?
  3. wezza2
    wezza2
    Jan 14, 2008
    15
    Hi this remote can be programmed with a 3 digit code so it can control the dvd sat cable and vcr.
    Plus I have posted in the other forums to
  4. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Right - I thought it was only sat and cable.
    Tosh don't use many codes - you've tried all those that are available for other models?
  5. wezza2
    wezza2
    Jan 14, 2008
    15
    Thanks i have tryed all the codes i can find if anyone know of a list of tosh code please let me know.
  6. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Just one other thought - some universal remotes have an option, when you don't have the specific code, to let you try cycling through all the available codes for a type of device - doesn't that apply to this remote?
  7. eiren
    eiren
    Oct 12, 2007
    11,215
    +2,796
    I'm looking for this too, should be a 3 digit code specific to Toshiba HD-DVD players that will work on a universal remote.
    Still no known code?
  8. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    A 3 digit code would be specific to Tosh's, not to universals.
    Which remote do you have?
