Blackbolt360
From hdtvorg.co.uk:
The Samsung LE32R87BDX like the rest of the R87 range is a real work of art. Glossy black finish, elegant bevelled undercarriage with hidden speakers and swivel stand will create an impressive centrepiece for any living space.
The R87 range from Samsung forms the companies new base range LCD TVs, but as such, connectivity and features will not be found wanting. Three HDMIs are accompanied by 2 Scarts, component video, pc input and an Integrated Digital TV tuner (IDTV) for Freeview.
Reviews:
http://www.hdtvorg.co.uk/reviews/lcd/samsung_le32r87bdx.htm
http://www.*/Samsung-LE32R87BDX/
http://reviews.cnet.co.uk/televisions/0,39030218,49290395,00.htm
Pictures:
Difference in Model numbers:
R86 - White with Front Center Power Button
R87 - Black with Front Center Power Button
R88 - Black with Right side touch sensitive power button and blue LED below Samsung logo. (Exclusive to DSG Group, Currys, Dixons & PC World)
PDF Manual:
Download the PDF manual here.
Below you will find a collection of settings for your Samsung R8 LCD Television. Remember, These settings are just a guide, a starting point to adjust to your own liking. Many people prefer to have high contrast images with little to no shadow detail. The settings below have been created to try to capture natural colours and show the full range of detail while maintaining good black/white detail.
Updated Settings: Tuesday 1st January 2008:
- Updated: Xbox 360 via HDMI (Now using 720p/Just Scan combo)
- Added: Curly99's Freeview settings.
- Added: Xbox 360 Elite via HDMI settings.
- Updated: Virgin Media (not V+) via RGB SCART.
- Added: Nintendo Wii via Component.
Special Note for PC Users: When using a PC, you can use a DVI to HDMI convertor on HDMI Port 2 and have 1360x768 output. This means you can do 1:1 Pixel Mapping via a 100% digital signal, this is the best signal this TV can ever recieve and display, much better than using VGA.
Note for Sky/Virgin TV Users: If you want to veiw 4:3 channels unstretched, then I recommend you use the following picture size settings on the input.
Screen Mode: 4:3
Most of the settings below where calibrated using Calibration Images found here. You can view them via media sharing on your various devices over network or USB stick.
Sky Remote Code:
0646
Service Menu Options:
Ok, the first stop is the Service menu. Now alot of people will tell you not to enter this menu as it will void your warranty, so this is your call. I personally have found that disabling Dynamic Dimming stopped a banding issue I was having, most noticeable in dark scenes. It also stopped the backlight changing levels too slowly when moving from dark scenes to bright scenes. Backup any settings you change, incase you need to restore them.. Be very careful many people press things without realising what they are doing and it is possible to ruin your TVs settings.
To enter the Service Menu, key in the following button combination in sequential order, not holding them down, tap one, then a very short pause, then the next, while the TV is in standby:
INFO + MENU + MUTE + POWER
Now adjust the following settings ONLY in the Adjust menu option:
Dynamic Dimming: Off (This stops the screen flickering when it changes from dark to light scenes quickly and vice versa)
Dynamic Contrast: On
Dynamic CE: Off
Press Power to Exit and save settings, leave it a second and power back on.
Input Settings Options:
VGA Input - Xbox 360 - High Definition - 1:1 Pixel Map @1360x768:
For Xbox 360, in the May 2007 Dash Update, they introduced a new setting called "Reference Levels", this is essentially a Gamma fix for the washed out VGA. It helps alot that Microsoft have introduced the fix at their end, helps us with calibration at this end.
_______________________________________________________
Auto Adjusting Samsung R8 to Xbox 360 at 1360x768p via VGA.
Firstly you need the following calibration image:
1: Jpg_image
2: Rar_file
3: Zip_file
This image is exactly 1360x768 and contains the necessary curves and lines for your R8 Samsung to auto adjust to, to give a sharp, clear picture.
The easiest way to view the image on your TV is to put it on a USB Stick or Hard-drive or similar device and then plug that into the USB port on the front of your Xbox 360 and then view the image from the picture viewer, selecting the USB device and navigating to the correct location.
You can also share over a network, There is a brilliant guide here. When you have added your image to your library within WMP11 or Zune Software, browse to the image via the COMPUTER share on your Xbox 360.
Auto Adjusting.
Now with the image on screen, make sure any xbox 360 GUI features have faded out, this includes any info panels across the top or the control panel. On your TV remote, press MENU, then go down to the 4th option and choose PC. Here there will be an option to auto adjust. When you press Auto Adjust your screen will go black for a few seconds, do not press anything until it comes back on.
You should now have the sharpest possible image from 360 you can get with this TV. Enjoy.
Xbox 360 Reference Level: Expanded
Xbox 360 Dash Resolution: 1360x768
Home Theatre PC: On (enable first to unlock Detailed settings.)
Game Mode: On (less motion blur, sharper picture)
Energy Saving: Off
Picture Mode: Standard
Contrast: 91
Brightness: 44
Sharpness: 50 (Greyed Out)
Colour: 55 (Greyed Out)
Tint: 50/50 (Greyed Out)
Colour Tone: Normal.
Backlight: 8
Detailed Settings:
Black Adjust: Off (or On if you prefer a higher contrast image)
Dynamic Contrast: Off (or On if you prefer brighter image)
Gamma: 0
Edge Enhancement: Off (Greyed Out)
Colour Space: Wide
White Balance:
R-Offset: 12
G-Offset: 14
B-Offset: 15
R-Gain: 13
G-Gain: 15
B-Gain: 15
My Colour Control:
Pink: 15
Green: 15
Blue: 15
White: 15
Sound Mode: Custom
SRS TX XT: On
HDMI - XBOX 360 Elite - High Definition - 720p (1080i will cause motion blur):
These settings are now prefered over the 'Optimal Resolution' dashboard setting of 1360x768. The colour depth is greater, richer and theres more options available when using the 720p resolution. Plus with the 1360 resolution you can't play 50hz only xbox games, with 720p you can.
Xbox 360 Dash Resolution: 720p
Game Mode: Off
Energy Saving: Off
Picture Mode: Dynamic
Contrast: 93 (lowest point before white becomes too bright & detail is lost)
Brightness: 61 (highest point before black detail is lost)
Sharpness: 44
Colour: 48
Tint: 50/50
Colour Tone: Cool1.
Backlight: 8
Size: JUST SCAN (This is extremely important as it will adjust the picture to fit the screen properly)
Digital Noise Reduction (DNR): Off
Active Colour: On
DNIe: Off
For sound use your own preference.
HDMI - PS3 Playstation 3 - High Definition - 720p/1080i:
Mode : Movie
Contrast : 80
Brightness : 48
Sharpness : 43
Colour : 43
Tint : 50/50
Colour Tone : Warm 2
Backlight : 8
Digital NR : Off
Movie Plus : On
Black Adjust : Med
Dynamic Contrast : Low
Gamma : +1
R Offset : 14
G Offset : 16
B Offset : 13
R Gain : 4
G Gain : 15
B Gain : 12
Pink : 13
Green : 13
Blue : 10
White : 12
Edge Enhancement : On
Colour Space : Auto
HDMI Black Level : Low
Game Mode: Off
Energy Saving: Off
Thanks to dazed808!
Or try Shade-X's settings:
Mode: Game Mode On
Contrast: 85
Brightness: 70
Sharpness: 50
Colour: 65
Tint: 50/50
Colour Tone: Cool1
Backlight: 10
Digital NR: Off
DNle: On
Movie Plus: Off
HDMI Black Level: Low
Energy Saving: Off
Every thing else should be kept on default
Or try therock500's settings:
Full RGB + Super White
Mode: Game Mode On
Contrast: 80
Brightness: 67
Sharpness: 50
Colour: 50
Tint: 50/50
Colour Tone: Cool1
Backlight: 7
Digital NR: Auto
DNle: On
Movie Plus: Off
Energy Saving: Off
PS3 - HDMI 720P - 1080i - 1080P
Curly's PS3 settings
NB: made a few slight changes to the ones I posted earlier.
PS3
RGB Full Range (HDMI): Limited
Y Pb/Cb Pr/Cr Super White: Off
TV
Mode: Standard
Contrast: 82
Brightness: 64
Sharpness: 15
Colour: 45
Tint: 57/43
Colour Tone: Normal
Backlight: 7
Digital NR: Off
DNie: on
Movie Plus: Off - Grayed out
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space: Auto
White Balance
R-Offset: 15
G-Offset: 15
B-Offset: 15
R-Gain: 6
G-Gain: 15
B-Gain: 18
My Colour control
Pink: 8
Green: 11
Blue: 11
White: 17
Game Mode: Off
Energy Saving: Off
HDMI - Upscaling DVD Player - High Definition - 720p/1080i:
Mode : Standard
Contrast : 85
Brightness : 53
Sharpness : 25
Colour : 35
Tint : 50/50
Colour Tone : Normal
Backlight : 10
Digital NR : Off (removed image retention)
DNIe : On
Movie Plus : Off
Black Adjust : High
Dynamic Contrast : Off
Gamma : +1
R Offset : 15
G Offset : 15
B Offset : 15
R Gain : 4
G Gain : 15
B Gain : 18
Pink : 12
Green : 11
Blue : 11
White : 14
Colour Space : Auto
Thanks to juneau!
HDMI - Windows Media Centre PC - High Definition - 1280x720p @ 50Hz:
Mode : Dynamic
Contrast : 73
Brightness : 54
Sharpness : 37
Colour : 35
Tint : 51/49
Backlight : 6
Active colour: Off
DNIe : On
Energy saving: Off
HDMI blacks: Normal
I found that Black adjust and HDMI black level made it too dark - there was no depth to the blacks. As for the PC, there is as far as I know, no image processing being applied to the video signal. The video card is a Nvidia 6200 shoving it all out over DVI.
Thanks to 16to9
HDMI - Virgin V+ HD Cable Box - High Definition - 720p/1080i:
Mode : Movie
Contrast : 85
Brightness : 51
Sharpness : 22
Colour : 47
Tint : 50/50
Backlight : 7
Digital NR : Off
Movie Plus : On
Black Adjust : Off
Gamma : +1
R Offset : 15
G Offset : 15
B Offset : 15
R Gain : 4
G Gain : 15
B Gain : 15
Pink : 12
Green : 11
Blue : 11
White : 14
Colour Space : Auto
Thanks to dazed808!
HDMI - SkyHD - High Definition - 720p/1080i:
Sky Box Contrast: Medium
Mode : Standard
Contrast : 90
Brightness : 55
Sharpness : 45
Colour : 50
Tint : 50/50
Backlight : 8
Digital NR : Auto
Movie Plus : Off
Black Adjust : High
Gamma : 0
R Offset : 17
G Offset : 15
B Offset : 11
R Gain : 4
G Gain : 14
B Gain : 30
My Colour Control: Default
Colour Space : Wide
DNIe: Off
Sound Mode: Standard
SRS TX XT: On
Auto Volume: On
Energy Saving: Off
Thanks to mat060572!
Component - Xbox 360 & Xbox 1 - High Definition - [email protected]:
Picture Mode: Movie (allows Detailed settings access)
Contrast: 74
Brightness: 45
Sharpness: 57
Colour: 58
Tint: 50/50
Colour Tone: Normal
Detailed Settings:
Black Adjust: High
Gamma: 0
Colour Space: Wide
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 4
G-Gain: 14
B-Gain: 30
Backlight: 9
Digital NR (Noise Reduction): Off
Movie Plus: On for TV shows, Off for Movies.
Sound Mode: Standard(Speakers on R88 aren't too good, recommend a proper speaker system)
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Component - Nintendo Wii - 480p:
Game Mode: On
Energy Saving: Off
Contrast: 73
Brightness: 50
Sharpness: 35
Colour: 55
Tint: 59/41
Backlight: 7
Digital NR: Off
DNIe: On
Movie Plus: Off
Detailed Settings:
Black Adjust: Medium
Dynamic Contrast: Low
Gamma: 0
Colour Space: Wide
White Balance:
R-Offset: 15
G-Offset: 15
B-Offset: 15
R-Gain: 15
G-Gain: 15
B-Gain: 15
My Colour Control:
Pink: 15
Green: 15
Blue: 15
White: 15
Home Theatre PC: Off
Sound Mode: Custom
SRS TX XT: On
Thanks to don rosco.
RGB SCART - Sky & Sky Plus - Standard Definition
Sky Remote Code: 0646
Contrast: 80
Brightness: 50
Sharpness: 30
Colour: 50
Tint: 50/50
Colour Tone: Normal
Backlight: 10
DNIe: Off
Movie Plus: Off
Sound Mode: Standard (Speakers on R88 aren't too good, recommend a proper speaker system)
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Thanks to bighairybloke
RGB SCART - Virgin Media Cable Box (not V+) - Standard Definition
Contrast: 90
Brightness: 53
Sharpness: 45
Colour: 46
Colour Tone: Normal
Backlight: 10
Active Colour: On
DNIe: On
Movie Plus: On (Totally personal Preferance, some prefer it off. If you get juddering or unnatural motion, then turn this off.)
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
RGB SCART - Gamecube - Standard Definition
These settings were calibrated with Zelda Twilight Princess, they may differ for main gamecube usage.
Contrast: 74
Brightness: 46
Sharpness: 50
Colour: 55
Tint: 50/50
Colour Tone: Normal
Backlight: 8
Detailed Settings:
Dynamic Contrast: Medium
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
My Colour Control:
Pink: 15
Green: 15
Blue: 15
White: 17 (Adds a sharper white, better image quality)
Active Colour: On
DNIe: On
Movie Plus: On (Makes the game look more 3D by artificially increasing FPS.)
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Freeview Built-in Tuner
Mode: Movie
Contrast: 75
Brightness: 55
Sharpness: 0
Colour: 35
Tint: 50 - 50
Colour Tone: Warm2
Back Light: 4
Digital NR: off
Active Colour: off -Grayed out
DNie: off - Grayed out
Movie Plus: Off
Detailed Settings
Black Adjust: high
Gamma: -3
Colour Space: Auto
White Balance
R-Offset: 3
G-Offset: 15
B-Offset: 15
R-Gain: 9
G-Gain: 15
B-Gain: 15
My Colour Control
Pink: 2
Green: 15
Blue: 15
White: 20
Energy Saving: Auto
Thanks to Curly99 Updated 03/04/2010
Don't Forget to press the Thanks button
Reviews:
Pictures:
PDF Manual:
Screen Mode: 4:3
Sky Remote Code:
0646
Dynamic CE: Off
1: Jpg_image
2: Rar_file
3: Zip_file
Auto Adjusting.
Energy Saving: Off
Contrast: 91
Brightness: 44
Backlight: 8
Detailed Settings:
Gamma: 0
Colour Space: Wide
White Balance:
R-Offset: 12
G-Offset: 14
B-Offset: 15
R-Gain: 13
G-Gain: 15
B-Gain: 15
My Colour Control:
Pink: 15
Green: 15
Blue: 15
White: 15
Sound Mode: Custom
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Sharpness: 44
Colour: 48
Tint: 50/50
Colour Tone: Cool1.
Backlight: 8
Active Colour: On
DNIe: Off
Mode : Movie
Contrast : 80
Brightness : 48
Sharpness : 43
Colour : 43
Tint : 50/50
Backlight : 8
Digital NR : Off
Movie Plus : On
Black Adjust : Med
Gamma : +1
R Offset : 14
G Offset : 16
B Offset : 13
R Gain : 4
G Gain : 15
B Gain : 12
Pink : 13
Green : 13
Blue : 10
White : 12
Colour Space : Auto
Game Mode: Off
Energy Saving: Off
Thanks to dazed808!
Mode: Game Mode On
Contrast: 85
Brightness: 70
Sharpness: 50
Colour: 65
Tint: 50/50
Colour Tone: Cool1
Backlight: 10
Digital NR: Off
DNle: On
Movie Plus: Off
Energy Saving: Off
Mode: Game Mode On
Contrast: 80
Brightness: 67
Sharpness: 50
Colour: 50
Tint: 50/50
Colour Tone: Cool1
Backlight: 7
Digital NR: Auto
DNle: On
Movie Plus: Off
Energy Saving: Off
PS3
TV
Mode: Standard
Contrast: 82
Brightness: 64
Sharpness: 15
Colour: 45
Tint: 57/43
Colour Tone: Normal
Backlight: 7
Digital NR: Off
DNie: on
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space: Auto
White Balance
R-Offset: 15
G-Offset: 15
B-Offset: 15
R-Gain: 6
G-Gain: 15
B-Gain: 18
My Colour control
Pink: 8
Green: 11
Blue: 11
White: 17
Game Mode: Off
Energy Saving: Off
Mode : Standard
Contrast : 85
Brightness : 53
Sharpness : 25
Colour : 35
Tint : 50/50
Backlight : 10
DNIe : On
Movie Plus : Off
Black Adjust : High
Gamma : +1
R Offset : 15
G Offset : 15
B Offset : 15
R Gain : 4
G Gain : 15
B Gain : 18
Pink : 12
Green : 11
Blue : 11
White : 14
Colour Space : Auto
Thanks to juneau!
Mode : Dynamic
Contrast : 73
Brightness : 54
Sharpness : 37
Colour : 35
Tint : 51/49
Backlight : 6
Active colour: Off
DNIe : On
Energy saving: Off
HDMI blacks: Normal
Thanks to 16to9
Mode : Movie
Contrast : 85
Brightness : 51
Sharpness : 22
Colour : 47
Tint : 50/50
Backlight : 7
Digital NR : Off
Movie Plus : On
Black Adjust : Off
Gamma : +1
R Offset : 15
G Offset : 15
B Offset : 15
R Gain : 4
G Gain : 15
B Gain : 15
Pink : 12
Green : 11
Blue : 11
White : 14
Colour Space : Auto
Thanks to dazed808!
Mode : Standard
Contrast : 90
Brightness : 55
Sharpness : 45
Colour : 50
Tint : 50/50
Backlight : 8
Digital NR : Auto
Movie Plus : Off
Black Adjust : High
Gamma : 0
R Offset : 17
G Offset : 15
B Offset : 11
R Gain : 4
G Gain : 14
B Gain : 30
Colour Space : Wide
DNIe: Off
SRS TX XT: On
Auto Volume: On
Energy Saving: Off
Contrast: 74
Brightness: 45
Sharpness: 57
Colour: 58
Tint: 50/50
Colour Tone: Normal
Detailed Settings:
Black Adjust: High
Gamma: 0
Colour Space: Wide
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 4
G-Gain: 14
B-Gain: 30
Backlight: 9
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Game Mode: On
Energy Saving: Off
Contrast: 73
Brightness: 50
Sharpness: 35
Colour: 55
Tint: 59/41
Backlight: 7
Digital NR: Off
DNIe: On
Movie Plus: Off
Detailed Settings:
Gamma: 0
Colour Space: Wide
White Balance:
R-Offset: 15
G-Offset: 15
B-Offset: 15
R-Gain: 15
G-Gain: 15
B-Gain: 15
My Colour Control:
Pink: 15
Green: 15
Blue: 15
White: 15
Sound Mode: Custom
SRS TX XT: On
Contrast: 80
Brightness: 50
Sharpness: 30
Colour: 50
Tint: 50/50
Colour Tone: Normal
Backlight: 10
DNIe: Off
Movie Plus: Off
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Contrast: 90
Brightness: 53
Sharpness: 45
Colour: 46
Colour Tone: Normal
Backlight: 10
Active Colour: On
DNIe: On
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Contrast: 74
Brightness: 46
Sharpness: 50
Colour: 55
Tint: 50/50
Colour Tone: Normal
Backlight: 8
Detailed Settings:
Gamma: 0
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
My Colour Control:
Pink: 15
Green: 15
Blue: 15
Active Colour: On
DNIe: On
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
Mode: Movie
Contrast: 75
Brightness: 55
Sharpness: 0
Colour: 35
Tint: 50 - 50
Colour Tone: Warm2
Back Light: 4
Digital NR: off
Movie Plus: Off
Detailed Settings
Black Adjust: high
Gamma: -3
Colour Space: Auto
White Balance
R-Offset: 3
G-Offset: 15
B-Offset: 15
R-Gain: 9
G-Gain: 15
B-Gain: 15
My Colour Control
Pink: 2
Green: 15
Blue: 15
White: 20
Energy Saving: Auto
