Samsung R74 Vs. Xbox360
N
Nightdog
Need a little help please, not sure if i'm just being stupid. I just got a samsung R74 32". I tried to connect up a xbox 360 using 15pin pc hd cable which has 2 audio jacks on it. This is an official cable, not something i mocked up. However, no matter which set of audio ports i use on the tv i get no sound. There is a small audio jack next to the pc connector but the lead does not fit this. The shop where i bought the lead have a samsung and 360 set up for their demo and assured me that the pc cable was the best option. Without sound i doubt that....any clues if i'm doing anything wrong or does the R74 not support the pc in plus 2 audio sockets combination?? Desperate for an answer....please help
C225
there should be an adapter with the hd cable to convert the two audio leads to the jack input on the tv. If you cant find it they can be bought for 2 quid from maplin here
N
Nightdog
Thanks for the info. Have you connected the same way and if so is there any noticable difference in sound quality and distribution?
C225
I had i connected that way for a while and the sound was fine. I now have it connected to some speakers.
