Samsung R74, Playstation 2 component cables?
degen8
I attempted to use my PS2 via component cable the other night and my Sammy r74 said that the video mode is not supported.
Is it that the output is too low? And if so am I likely to suffer the same problem with the Wii over component?
Is there settings that I should be aware of?
Gold Feet
You should be ok, my Gamecube works fine with PAL and NTSC over Component, the Samsung has a very good Composite input if you still get problems.
degen8
I made a bit of a cock up. There is a setting on the PS2 from RGB to Yr/??/?? and it now works fine.
I was just being a little dim.
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
