samsung r7 motion blur
hasantheman
hi guys going to get a 40 samsung r7 tomorow but a friend of mine is saying get a plasma as the motion blur on the r7 is bad
it will b for my 360 mostly is the samsung good with the 360 ?
thanks:lease:
alistair_mitche
amazing on the sammy - i have a 32 but is is great. Normal viewing is very good and like all LCD is does have some motion blur - end of th eday your call.
If you have HD via sky / telewest (like i do) then it is fine.
Nielo TM
thanks:lease:
Whats your budget?
Similar threads
