Samsung R580 temperatures too high?
Discussion in 'Desktop & Laptop Computers Forum' started by elsmandino, Sep 10, 2012.
  1. elsmandino
    elsmandino
    Jul 18, 2009
    353
    +10
    Hello,
    I have had an R580 for a couple of years now and it seems to getting really hot, even when just idling.
    This is something that I have never really thought about before as I know laptops generally run hotter due to confined spaces.
    I have just checked the temperatures with SpeedFan and it says that the GPU and CPU core temperatures are all at around 70 degrees when the computer is not doing anything.
    Is this normal or do I have a temp issue?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,732
    Norfolk
    +2,492
    70°C is fine for CPU/GPU temperature, but it's worth checking it when you've loaded it up to see what it is. Generally the sign that it's getting too high is that the CPU won't run at it's full speed so keep an eye on clockspeed when you do so.
