samsung question
Discussion in 'Samsung TVs Forum' started by wolf600, Jun 2, 2003.
  1. wolf600
    wolf600
    hi guys and gals,
    question, would a iScan Ultra or something else pref abit cheaper boost the picture quality, so less artifacts and solarisation on my samsung ps42p2sbx {the one with the tuner},
    and how would you connect it to the tuner which has all my scarts etc conected to it??
    cheers
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    if your using your internal tuner to display the picture
    then i doubt the iscan is of any use to you.
    the iscan is the link between the signal source and the display.
  3. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    I've heard that using such a device as the iScan does improve the video processing of the Samsung, but I've not seen it myself.
    All the best,
    Dr John Sim.
  4. wolf600
    wolf600
    i have the one with the external turner,the picture is driving me mad, i might have to return it...
  5. Mats1
    Mats1
    Is the picture really so bad? I ordered one of these babies and now all I read is bad opinions.
    When I've seen it at the store, the Samsung did not appear being so much worse than a Panasonic (flickers - nothing for me).
    I liked the Philips, that one however was too expensive.
  6. wolf600
    wolf600
    to be really honest the picture is not that bad on certain sky progs,my problem i have been having is real bad solarisation {if thats what it is} on peoples faces and in really dark scenes,but my screen is faulty and was changed this am for a new one BUT the new one had a pink line down the middle of the picture so i am back to the original screen so i dont know how good the samsung is with a proper working screen.
    if you can change your order i think you will be a happier man in the end {thats my personal opinion only mate}
