LuciusFox
Established Member
@Phil Hinton - more importantly, when is the review of the Sony OLED coming?
The TV likely has a 100mb network porti have the S95B 65" and a Question about Internet speed,
Network connection speed through NetFlix on TV is always around 94Mbps. (Ethernet Wired)
I have a Fire TV stick 4K Max, and the same test gets 225Mbps on Wi-Fi
i have a 1 GIG speed, and always get 950Mbps ethernet speed on my Laptop. (Com Fibre.)
is the network Speed limited to just 100 Mbps or can i change any setting?
TIA
Mine has (had) that buzzing issue. Samsung remotely "fixed" it by totally ruining the sound profile Sent out a tech who could not change it back Trying to get a refund or replacement atm ...sadEven at low volume the internal chasis and/or the flimsy back panel is resonating, vibrating and buzzing destroying the viewing experience. Dosn't have to be a hi fidelity streamed signal just a terestrial broadcast will do it in a certain tonal range.
Firmware bug. Stop upgrading firmware. Always wait until someone else do it for you. Then you can upgrade firmware. Is better block updates and wait you don't loose nothing.Hello, I'm from Austria.
in game mode, i have flashes of color and brightness for a brief moment when changing scenes, for example in cutscenes. light gray briefly turns pink and then normal. skin tones lighten briefly and then normal. this only happens in game mode with local dimming high and standard. with local dimming low everything is normal but with bad black.
i play in SDR.
firmware is 1403.1
