Samsung QN 94A Connections
kerby1991
Have been using Samsung KS 7000 plugged all my inputs into Yamaha YSP-2700, found it easier than using one connect box, but am i right in thinking will have to plug Virgin V6 box straight into tv to use BBCI Player because of HLG FOR 4K Also would there be any advantage in plugging my UHD player into the 2.1 HDMI input, or just leave as is plugged into Soundbar, then hopefully can just use ARC from Soundbar into E-ARC on the tv ?
cuke2u
According to post #4 the Yamaha will passthrough HLG so either or...
Depends upon whether you experience audio lag..
kerby1991
At the moment plugged Virgin V6 box into HDMI 1 on tv UHD player into HDMI 2 V6 box working fine no audio lag, not tried UHD player yet, run cable from ARC on soundbar to E-ARC on tv working with no problems, not altered any picture settings as yet, tv remote now seems to control volume on soundbar not sure how that works ? will muck about with things Tomorrow, wish me luck.
kerby1991
Have altered some settings on tv, not getting any judder at the moment but where is the motion clarity did not see it when altering settings, do you have to be in a certain picture mode ?
