Samsung qe75q8dn
Discussion in 'LCD & LED LCD TVs Forum' started by Knocker07, Apr 26, 2019.
Tags:
  1. Knocker07
    Knocker07
    Feb 8, 2016
    84
    Preston
    +22
    Hi putting this in conservatory as I have oled b6 have I made right choice which is best hdim budget lead from dennon amp. Will i appreciate the qled over oled in conservatory many thanks arrives Tuesday £2250
  2. Knocker07
    Knocker07
    Feb 8, 2016
    84
    Preston
    +22
    As I can not see oled in dark pics
  3. Knocker07
    Knocker07
    Feb 8, 2016
    84
    Preston
    +22
  4. Knocker07
    Knocker07
    Feb 8, 2016
    84
    Preston
    +22
    How do I know when playing hdr example Netflix as oled says it in corner of screen thanks
  5. next010
    next010
    May 29, 2005
    10,887
    163
    +2,138
    It is not recommended to have OLED's in rooms were direct sunlight hits the screen, if the TV is always in the shade that is fine but you run the risk of getting burn in on the OLED panel if direct sunlight shines on it over the long term.
    Click the wheel on the LG remote and select and click on the the banner bar at the top of the screen, it will list picture details saying resolution (2160p = 4K) and if it's in HDR. Also the picture display presets will be listed as HDR variants if you go into picture settings.
  6. Knocker07
    Knocker07
    Feb 8, 2016
    84
    Preston
    +22
  7. Knocker07
    Knocker07
    Feb 8, 2016
    84
    Preston
    +22
    Thanks for that mate
