Hi all. Can someone help me with the differences between the 50 inch UK Samsung QE50QN90 and QE50QN94 models (apart from €100 price difference!) please? Having a different spec for the smaller screens in the range makes it difficult to spot the differences.
Depending on where you read, both appear to be VA panels, both have wide viewing angle.
I had seen some comments that the QN94 models have better speakers, but both 50" models only have OTS lite instead of OTS+. It would be nice to have better sound without a soundbar.
Quantum HDR 1500 on the QE50QN90 and quantum HDR 2000 on the QE50QN94 appears to be the only difference. The television won't be used in a bright room, so the HDR 2000 isn't a requirement, my concern is that it could be almost too bright!
Anything else that I am missing? Unfortunately, a bigger screen is definitely not an option, the 50" will already push the space in the alcove.
Thanks for any help or recommendations!
