Quantcast
Samsung Q9FN 65 One Connect Box Dual Voltage?
rukesh458
Hello,
Enjoying my Q9FN 65 so far. Bought the TV in US (120V). I am planning to move to India and will be taking the TV with me. Researching the internet for a bit and found that Samsung uses dual voltage SMPS (can use both 120V & 240V connections) on some of the models. Is anybody able to confirm if the Q9FN 65 One Connect is dual voltage? Thanks!
rukesh458
110-120V~50/60Hz
This was bought in the US. Researching online showed that Samsung put the voltage of the region on the label. But internally it has dual voltage. Tried opening up the box to check, but it is sealed pretty good and I don't want to break it. Checking if anyone had opened up the box to check or tried plugging it to a different region power. Thanks!
