Samsung Q90R QLED Owners and Discussion Thread
Bal
Is £1600 a good price in today's market for the 65"?
yes, I paid slightly less a couple of months back but not seen it cheaper since so £1600 is a very good price for the TV you’re getting. Think it was circa £3500 at launch!
Rando
Think I'll push for less, got another tv to buy at the same time so hopefully they'll do something.
Eavivi
Here is my settings. They work best for me. hope it helps.
SDR (TV freeview)
Movie mode
16:9 standard
Autowide enabled
4:3 screen size 16:9 standard
Fit to Screen On
Backlight: 37
Brightness: 0
Contrast: 40
Sharpness: 0
Colour: 25
Tint (G/R): 0
Apply Picture Settings: Current Source
Digital Clean View: Off
Auto Motion Plus Settings: Custom
Blur reduction 10
Judder reduction 3
LED clear motion off
Local Dimming: Standard
Contrast Enhancer: Low
Film Mode: Off
Colour Tone: Warm2
White Balance
2 point
Red gain +8
Green Gain 0
Blue Gain +8
Red Offset 0
Green Offset +2
Blue Offset +4
20 point setting off
Gamma: BT.1868
BT.1868: 0
RGB Only Mode: Off
Colour Space Settings: Auto
SDR (Apps - Youtube/Netflix/Amazon/BBC)
Movie mode
Backlight: 38
Brightness: 0
Contrast: 41
Sharpness: 0
Colour: 26 (find it slightly better than 25)
Tint (G/R): 0
Blur reduction 10
Judder reduction 3
Film Mode: Off
Colour Tone: Warm2
White Balance
2 point
Red gain +8
Green Gain 0
Blue Gain +8
Red Offset 0
Green Offset +2
Blue Offset +4
Gamma: BT.1868
BT.1868: 0
RGB Only Mode: Off
HDR (Apps - Youtube/Netflix/Amazon/BBC)
Movie mode
Backlight: 48
Brightness: 0
Contrast: 46
Sharpness: 0
Colour: 25
Tint (G/R): 0
Blur reduction 10
Judder reduction 3
Contrast Enhancer: High
Film Mode: Off
Colour Tone: Warm2
White Balance
2 point
Red gain +22
Green Gain 0
Blue Gain +3
Red Offset +4
Green Offset +1
Blue Offset +4
Gamma: ST.2084 - 0
RGB Only Mode: Off
Games -PS4 pro
I connected my PS4 pro via Yamaha RX681 (HDMI) then output from RX681 to Q90R HDMI3(ARC),
If I connect the PS4 pro via Q90R HDMI4 then the sound goes via Q90R HDMI3 to the RX681 I do get sound delay and distortion.
PS4 pro settings
Video output setting
Resolution 2160p-RGB
RGB range - Auto
HDR auto
Deep colour Auto
SDR
Game mode
Backlight: 30
Brightness: 1
Contrast: 40
Sharpness: 0
Colour: 25
Tint (G/R): 0
Local Dimming: standard
Contrast Enhancer: off
Film Mode: Off
Colour Tone: Warm1 (you can try warm 2 if it is too blue for you)
White Balance
2 point
Red gain 0
Green Gain 0
Blue Gain 0
Red Offset 0
Green Offset 0
Blue Offset 0
BT.1868: 0
RGB Only Mode: Off
External Device Manager
HDMI Black Level - Low
Game Mode on
Game Enhancer On
Dynamic Black Equaliser 3
Game Motion plus On
Blur reduction 0
Judder reduction 0
Freesync off
HDR games
Backlight: 45
Brightness: 0
Contrast: 47
Sharpness: 0
Colour: 25
Tint (G/R): 0
Local Dimming: Low
Film Mode: Off
White Balance
2 point
Red gain 0
Green Gain 0
Blue Gain 0
Red Offset 0
Green Offset 0
Blue Offset 0
ST.2084: 0
RGB Only Mode: Off
Game Mode on
Game Enhancer On
Game Motion plus On
Blur reduction 0
Judder reduction 0
Freesync off
After you apply all the setting, then adjust the HDR on the PS4 pro
chuffster2005
I ask this a lot on various posts, so sorry if you've already seen it, but what would be the closest LCD/QLED tv to my almost defunct and out of warranty Sony ZD9?I have kids, so want to avoid Oled if possible.Watch a lot of movies, and play a lot of Xbox games.looking to get the Series X this year, too.Help appreciated guys.
Mike15111984
Hi Everyone,
Does anyone use contrast enhancer for hdr videos? I was watching a hdr demo on youtube yesterday, there is a part where the scene goes dark but it appears the tv overly darkens it, or i think it does lol anyway when turning on the contrast enhancer to low, the tv does not darken the scene down as much and more detail is present, so does it help with shadow detail/black crush? On the flip side of that, whites seem to loose detail, for example, hdr moon demo, some detail is lost in bright whites.
0.25 in as the lights switch off is the example of the tv overly darkening, when contrast enhancer is on them details don't disappear.
Example of the bright whites slightly losing detail with it on.
So is it a case of if you want more shadow detail at expense of bright detail, have it on low, if you want bright detail at expense of shadow detail leave it off?
Also if anyone wants a playlist of hdr demos, film clips and games, nature and just random hdr demo's, here is a link to my playlist which i update frequently.
CarMad
I've found similar and its currently on low as well, prefer to see some of the darker detail that it be lost with too much black crush.
Only had the 90R a short time but its incredibly impressive for movies for me.
Mike15111984
Yeah i was just messing around when i noticed it do that after turning CE on to low, will check other things to make sure if it's not a one off, then have to decide if to leave it on low or off.
MEGATAMA
So eARC will not fix sound lag...this is from other topic.
No EARC dosentthelp. My C9 with Beosound stage (both Earc) also suffer from lip sync :-( I have tried EVERYTHING. Only PCM sound helps a bit. But no multichannel then. Because of LG not mowing SW forward
cuke2u
On a precious c9?
Mike15111984
I don't know much about them but would these fiber optic hdmi cables help with lip sync issues? I read they are supposed to deliver a faster signal? Im not to sure on their specifications or their prices (im guessing quite pricey)
BoyVader
Not strictly true...Lip Sync Correction is part of the eARC standard...in fact it's mandatory..
JanB
Don't bother with other HDMI cables (of any kind). The problem with excessive audio delay (in the range of 100ms or more) for certain audio formats is caused by a bad implementation in these TV:s. I suspect that the delay is caused by the TV transcoding the signal. (Which can not be done fast enough.) A correct system solution should not require a time consuming transcoding.
MEGATAMA
In other topic they wrote that is Dolby fault thats why problem is on so many diferent tv sets.
Mike15111984
Ah right, thanks for the reply. I was not going to get one, just wondered if these would help people having this issue 👍
MEGATAMA
It was this topic.
CarMad
Fingers crossed the update for eARC arrives soon for those that want / need it and see what it fixes.
I'm going to my AVR first then onto the TV so the sound is already processed so no issues fortunately.
dEUS77
Is it possibile skip the problem with a 2 hdmi port bd player? 1 connected to the tv and the hdmi audio output to the avr?
JanB
It was this topic.
Thanks. I have searched through a couple of those pages. Can you point me to where someone posted more insight knowledge that Dolby (Laboratories) is to blame. (It seems to be caused by a common source for several manufacturers.)
Similar threads
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
Trending threads
Latest News
Philips TV and Bowers & Wilkins extend partnership
  • By Andy Bassett
  • Published
Denon unveils CEOL N11 DAB music system
  • By Andy Bassett
  • Published
Audeze announces Penrose wireless gaming headphones
  • By Andy Bassett
  • Published
Movies preferred to TV shows during lockdown in UK
  • By Andy Bassett
  • Published
Ruark announces R3 all-in-one music system
  • By Andy Bassett
  • Published
