Hi all
after days of tests and attempts, I'm about to give up..
I got a new Q80T with latest firmware, a Sony STR DN1050 with latest firmware as well (my surround system is connected to it), and an Xbox Series X.
I got a few problems:
1) Xbox says the Q80T doesn't support 4k 120, while in reality it does for devices connected to hdmi4 (what I did). I tried with original Xbox cable and another 2.1 8k cable, direct from Xbox to hdmi4 of the Q80t, no way for xbox to see 120 is supported (even after reboot/power cycle of both tv and xbox). Conmecting the xbox to the Sony amp and then from there to TV is not good as the Sony is old and doesn't support HDR and other stuff, so Xbox is connected directly.
2) audio level and universal remote! At the moment I have the optical out of the TV going into the optical in of the Sony amp, and that works for stereo and surround. BUT I want to change the volume level using my Universal Remote, and there's no way of making it work!
My smart remote is able to control xbox as I added it as a device, but if I add the Sony whatever I select, I command the volume only when the input on telly is on hdmi3 (where the sony is connected to telly in case I need to change its settings etc).
One idea was also ARC, enabled on q80t, enabled hdmi control on the Sony, yet no way to select as audio out on the q80t the arc port on hdmi3.
Honestly I have no idea what else to do to;
1) have q80t to be seen by xbox as a 4k 120
2) be able to control volume of audio (going to Sony STR DN1050) via smart remote
Any help/idea?
Any help/idea?
