Question Samsung Q80R & Q90R help please
drebins2003
Joined
Feb 11, 2010
Messages
30
Reaction score
2
Points
11
Age
52
Hi everyone just needing a little help if you don’t mind iv got myself a Samsung Q85R 65inch last week and not had much time to play with it but the sounds not brilliant so just ordered the Q90R sound bar that comes on Tuesday (carn’t wait😀) my question is do I need to upgrade the cables as I’m running cheap ones atm and will they make a difference?????
Not to contradict every salesperson in the land but the short answer is. No.
If you’re planning on using ARC which I assume you are, any HDMI cable will support this.
No, even if you want to upgrade you can get cheap HDMI 2.0b cables 18gbps for few dollars on amazon. The Amazon cables are good themself.
Is Home Theater DEAD in 2024?
Back
