samsung ps50c96hdx-samsung ht-thx25
Discussion in 'Home Cinema Buying & Building' started by lll-THE-CAT-lll, Sep 20, 2007.
  1. lll-THE-CAT-lll
    lll-THE-CAT-lll
    Sep 19, 2007
    5
    i have just purchased a samsung ps50c96hdx plasma tv and a samsung ht-thx25 all in one home cinema system
    i have upgraded the cable to connect these with a qunex hdmi-sr cable.
    now i was wanting what will be best to connect my sky+ up to the home cinema to get the best out of the speakers and any hacks as yet to make this home cinema system multi region
    and any other tips to get the maximin pleasure out of this set up
    :lease:
    THE CAT
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    the only way to connect sky+ to the samsung system,is with a set of red/white phonos,for audio,connected to AUX IN 2,on the samsung.
    so all you will get is stereo,unless you pick one of the effects on the samsung,to utilise the rear speakers,but even then,its just echo basically.
    as for dvd hacks,why not have a look in the dvd hacks forum-
    http://www.avforums.com/forums/forumdisplay.php?f=126
