Samsung PS50C96HDX covered in shinny blue pixels
Discussion in 'Samsung TVs Forum' started by PhAtTs79, Jan 16, 2008.
  1. PhAtTs79
    PhAtTs79
    Jan 14, 2008
    3
    hi guys! i'm pretty new to this forum but i have been here a few times looking up reviews for TV's and on quite a few peoples recommendation i got myself a C96HDX while it was on offer in September last year
    now, i found going from a rear projection 43" toshiba to the 50" was a MASSIVE improvement and i havent looked back and up until now its been a sweet buy but...
    i got home last night and turned on my xbox and TV and to my horror the image was tainted by evil blue pixels scattered all over the screen (main "press start" screen on CoD4) but mainly in the top corners and seemed to be moving along with the clouds - you guys that have this game may know what i'm on about, but other AV sources seemed fine
    i tried adjusting the contrast, brightness, screen size, DNi etc etc but no difference and the problem was getting worse but the minute?! turned it off then on from the main but still the same! played with the component cables on the back to check if proper contact was being made but no change...
    i then turned my eye to the xbox in my last breath of hope, off the on but again the same, switched the cable to standard TV and was fine... maybe the xbox?? so on that note i switched it back to HDTV and ta dah, blue pixels have vannished?!
    i've had the odd pixels showing through before watching DVD's but never playing a game and never on this scale, was almost replacing colours it couldnt reproduce? the problem seems sorted now but i've got feeling i'm gonna see those critters again so your advice would be appreciated!
    would it be the TV or does it sound like the xbox playing games? its an earlier xbox (the ones prone to the ring of death) but i've had no problems with it thus far
    your advice, reassurance etc etc is much needed!
    cheers guys!
  2. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    Sorry but my guess is voltage/ pcb problems does it occur on all inputs just to confirm if its just xbox you may be lucky
    regards
  3. eiren
    eiren
    Oct 12, 2007
    11,242
    +2,796
    If it's just on the XBox, sounds like the GPU on it might be on its way out.
  4. PhAtTs79
    PhAtTs79
    Jan 14, 2008
    3
    its just seems to be on the component which is what the xbox is plumbed into and as my Sky seems fine (a little grainy but i suppose thats poor reception) i'm feeling its either the 360 or the component on the TV
    since i switched the AV lead on the xbox to standard then back to HD it appears fine, it is one of the older 360's and i think it is one of the older ones that have the GPU overheating problem so i'm hoping its on its way out so i can get my hands on one with HDMI
    is there much difference in visual quality between HD component and HDMI on the 360? sorry, off the subject but out of interest ;)
  5. ced70
    ced70
    Mar 10, 2009
    I would say its heat.
