Quantcast
samsung ps43d450a2 any good
craigymuk
Hi i might be buying this later on and wanted to know if there any good it will replace my old 32inch Toshiba whichi got 2 years ago i would use it for xbox and virgin and blu ray flims thanks ppl its nice and cheap at the min
slc79
It's very good for its price range, and I doubt if you'd be able to find a better plasma for the price. Be aware that it's only 720p if that matters to you. I have a PS43D455 myself (should be the same thing, just for another region) and it's been way better that what I expected when purchasing it.
Badger0-0
Blimey, when you said "later on", I thought you meant further down the line :)
I'd have advised you go and have a look for yourself, but whatever, I don't think you'll be disappointed.
Let us know what you think of it :smashin:
craigymuk
Thanks for the help i know this is wrong part of forum but what the best surround sound and amp fir this tv thanks
Badger0-0
There is no best setup for that telly, it doesn't work like that.
But as much as you can afford is usually not far off the mark.
And you're right, it's totally the wrong place to ask :D
Similar threads
