Anybody help ive just won this in a prize draw at work and get it tom, Does it have any componant in. reason i ask is i have a componant XBOX lead and also a 757a pioneer and wanted to connect that also, If this doesnt have Componant in is there any special leads that do the same but via svhs or other connections on this Plasi. sorry for newb questions but only had TVs before
it has a component input, in fact i believe there's at least two in there so you can use component connections on both your xbox and pio 757 dvd player..... there's an ongoing thread about samsung plasmas and its "variants", you might wanna check it out here http://www.avforums.com/forums/showthread.php?t=141615 hth
it doesn't have 2 component inputs. Don't mean to put a downer on things but have just posted my opinions on this plasma onthe other thread currently running. Still, if you didn't shell out cash for it then its probably reasonable value. enjoy.
